i need help to find a motor that will slap right in an 89 b2200
Old 07-19-2013, 08:46 AM
meetybone's Avatar
Default i need help to find a motor that will slap right in an 89 b2200
hello yall my name is jesse i need help to find a motor to slap right in to my b2200 without mods done to inter fenders. also i did a tune up and everything to the motor i have in it, but it has no power at all it is also missing in cylinder 2 and 4 and i cant find out what it is i did tune up changed the coil i need help...
it is a 2.2l and i want one with more power anyone have a suggetion?
Old 10-14-2013, 07:42 AM
Junk Tech's Avatar
"Slap right in" sounds like you want a direct bolt in without any hassles. If so, and your engine is carb, then you have two choices for engine replacement. Another F2, 2.2 engine, or the FE, 2.0 engine from the B2000.
However, if your stipulation is "no fender mods", then prospects widen. The Fe3 from a Kia Sportage would work with the install of its wiring harness and computer. A Miata engine and trans could be installed, but it isn't a bolt in. A Ford V8 could be installed, as well as many other engine/trans combos. You can do these without fender mods, but you will have to modify engine and trans mounts, plus reroute hoses and wiring.
As said, the minimum of hassles is F2 or FE, with the F2 having a bit more low torque. I have a B2200 with an oil burning engine. I plan to run it while I find another B2200, or an F engine from somebody's garage, to rebuild and then "slap right in".
JT
Vorsath
12-02-2010 10:01 AM
Tfrag14
02-04-2010 01:52 PM
Suzuki191
08-03-2008 10:51 PM
longrange
11-26-2007 01:13 PM
chad85
03-13-2007 09:37 PM
Quick Reply: i need help to find a motor that will slap right in an 89 b2200
