Help, I Swapped Motors??
Old 05-04-2006, 06:07 PM
Mazdaboy2600i's Avatar
Default Help, I Swapped Motors??
I pulled the engine out of my 2-WD AND put in into my 4-WD, and it cranks, but will only run while i have my foot on the gas petal giving it gas...Inside the distbutor is all rusty lookin, i bought a new rotor for it, it has the vaccum advance on it, the arm on it is rusted, uh i had a new distrubutor for my 2-WD but it want fit my 2-WD becuase the plugs are different, and no vaccum advance on it. Any help would be great!!!!!!
Old 05-04-2006, 10:03 PM
babyhuey's Avatar
Default RE: Help, I Swapped Motors??
Does it seem to run normal at higher rpm's and just will not idle or does it run bad all of the time?
Old 05-05-2006, 01:00 AM
It want idle at all, i crank it up, and it will die, if i dont give it gas. Not sure what else to tell you??? any help...
Old 05-07-2006, 05:19 AM
have we tried adjusting the idle control screw yet? checking for vac leaks and all the other basics?
mazdaowner3
06-29-2013 04:44 AM
canuck42
08-08-2011 05:40 AM
thefall323
08-05-2011 10:10 PM
Btruckr
08-16-2005 01:16 AM
Quick Reply: Help, I Swapped Motors??
