front axle shaft replacement 2600i 4wd
Old 06-19-2007, 01:37 PM
2600duude's Avatar
Default front axle shaft replacement 2600i 4wd
How difficult is the axle shaft to replace (passenger side)????
Old 06-24-2007, 07:23 PM
Default RE: front axle shaft replacement 2600i 4wd
I am doing this right now, it is very aggrivating, the passenger side cv axletook me twice as long as the driver side because the passenger side was very hard to pull out of the differential.
Old 06-28-2007, 09:08 AM
I didn't have much of a problem with mine. The passenger side has a spline on it and it just pulls out of the differential. I bought remanufactured shafts for both passenger and driver side. IMO, the biggest pain was unbolting the steering knuckle to get the shaft out. Other than that, it wasn't bad. Suggestion: replace the inner seals so that you don't loose too much gear oil from the differential when you pull it. Not a hard job, though. Unbold the steering knuckle, slide the shaft out of the bearing, and give it a tug. It should just pop out of the right-side differential.
Old 06-29-2007, 07:20 AM
I had to take a crow bar and pry mine out it took a while.
willb3rd
11-07-2010 11:43 AM
Sipsey
03-21-2010 09:21 PM
Camo4x4
10-10-2008 10:20 AM
sstockton
08-15-2007 05:51 PM
Quick Reply: front axle shaft replacement 2600i 4wd
