brake check valve?
Old 11-24-2015, 01:02 PM
dragonmp5's Avatar
Default brake check valve?
93 b2600 2wd 5spd. I have come across this reference to a check valve in the braking system but cannot find anything except for emissions stuff. Can anyone clarify this for me? I have been wondering about this as a possible cause for losing pressure when pressing brake petal for booster testing. It builds up pressure then slowly releases it. While driving it feels a little soft. I have not bled brakes but plan on doing that tomorrow.
Old 11-26-2015, 06:06 AM
There will be a proportioning valve that splits the pressure front to rear. There may also be load proportioning valve on the rear axle to adjust brake bias from no weight to fully loaded tray.
A full clean & adjustment of the rear brake shoes & a full brake fluid flush is in order.
Old 11-26-2015, 08:31 AM
Cusser's Avatar
There is a check valve inside the short curved vacuum hose that leads right into the brake power booster. Is that what you mean?
Old 11-27-2015, 01:39 AM
dragonmp5's Avatar
I wasn't aware there was one in the hose. How do i test it?
Old 11-28-2015, 08:36 AM
Cusser's Avatar
Try to blow air through it; should only go in one direction. There is an arrow on the outside of the hose and states "to engine".
I haven't had one of these check valves go bad myself, but I've owned my '88 B2200 21 years now and have replaced the power brake booster exactly once. I have replaced the brake master cylinder several times over that time, and the calipers once each. I don't remember doing either rear wheel cylinder.
Old 11-28-2015, 07:12 PM
dragonmp5's Avatar
I'll check it out as soon as everything defrosts. We just had a small winter ice storm blow thru and everything is frozen till at least monday.
Rhodri
09-27-2013 02:06 PM
schlompie
03-06-2012 02:49 PM
rnunez1989
04-04-2011 11:56 AM
mtarajia
05-15-2007 02:24 PM
Quick Reply: brake check valve?
