Bolt Broke? Help
Old 04-24-2006, 02:03 AM
Mazdaboy2600i's Avatar
Default Bolt Broke? Help
I was taking my distrubutor out, and the bold broke off even with my head. I dont have a clue how to get of out. The truck is a 1989 Mazda B2600i 2.6 Liter Engine. Is there anyway i can drill it out, and twist it out, i am trying not to screw up the head... Thanks For ANY SUGGESTIONS!~
Old 04-24-2006, 04:48 AM
Default RE: Bolt Broke? Help
Go to your local auto parts store and ask for a tool called an "Easy Out", better known as a bolt extractor.
There are a few kinds. Some look like a drill bit that has reverse threads. It is tapered, so as it is being spun (left loosey, righty tighty) it will dig in to the bolt and then spin it out.
Not to be confised with a reverse drill bit, which will be needed anyway to start the hole for the easy out. The reason the drill bit has a reversed thread is that when you drill the bolt you don't spin it deeper into the hole. (yes, you literally put the drill in reverse to drill the hole INto the bolt)
Some easy outs are square and tapered without threads, this type has a sharpened edge the digs into the bolt as you turn it. Again you may need the reverse drill bit, though some Easy Outs you can pound with a hammer to start it.
Old 04-24-2006, 09:40 AM
sstlaure's Avatar
Or you can weld a slightly smaller bolt to the part that is still stuck in your head. The heat from the weld should tend to loosen what's left so that it breaks free.
Give that a try if the easy-out doesn't work. (I've broken a few of those before...)
Old 04-25-2006, 02:07 AM
Thanks Yall, i let my grandfather look at it, and he had the easy out tool thing in his shop, we drilled the hole, and tapped the tool in, and screwed it right out, thanks yall..
FrankMazda6
04-29-2011 10:31 AM
brokenkey
01-31-2007 03:32 PM
jackyl16
05-22-2006 10:53 PM
def328
03-16-2006 03:14 PM
ЌﺄÅÅÑ”Ñ
10-26-2005 01:39 AM
Quick Reply: Bolt Broke? Help
