B4000
Old 01-12-2006, 05:11 PM
jts's Avatar
jts
jts is offline
Default B4000
New to this board.
My 1997 B4000 has the 'brake' + 'abs' warning lights on ![]
Brakes work fine,fluid level fine.
Any suggestions ?[sm=icon_cheers.gif]
Old 01-13-2006, 08:23 PM
bkey71's Avatar
Default RE: B4000
When both these lights are on, that means the abs (anti lock brake) system sees a failure. Your normal brakes will work fine with no problem, you just do not have anti lock if you need it. You need to have the brake system codes read by a scan tool to know what the computer is seeing. It is most likely a wheel speed sensor (there are more than one) that is dirty or has gone bad.
Old 01-15-2006, 12:30 PM
jts's Avatar
jts
jts is offline
Default RE: B4000
ORIGINAL: bkey71
Thanks for the reply
I guess I'll pick a warmer day (-7C right now ) to have a look.
I think the abs sensor is mounted near the rear diff?
Old 01-16-2006, 12:27 AM
bkey71's Avatar
Default RE: B4000
It depends if you have rear wheel antilock or four wheel. If just rear wheel, the sensor should be located in the differential. If four wheel, there is also a sensor on each front wheel along with the differential.
Toytruckmike
03-30-2006 05:19 PM
Toytruckmike
03-23-2006 03:59 AM
Toytruckmike
03-23-2006 01:02 AM
def328
03-11-2006 11:30 AM
Tom73
11-18-2005 04:44 PM
Quick Reply: B4000
