B2300 Vibration
Old 02-26-2012, 05:56 AM
Flyboy22's Avatar
Thanks BC! I will give the driveshaft another look but as I mentioned initially, I replaced
u-joints, center bearing, had driveshaft inspected & balanced at a driveshaft shop, while I stood there watching. It was smooth running up through 90 mph.
Old 05-03-2019, 10:21 PM
Donald Walker's Avatar
Default I have the same problem you ever figure it out?
Originally Posted by Flyboy22
I'm totally out of ideas. 1996 Mazda B2300, 5 speed, 4 cyl., 125k miles I have a vibration in all speeds, all gears, diminishes considerably when under heavy acceleration. Replaced engine mounts, u-joints, center bearing, had driveshaft balanced, replaced clutch, pressure plate, throwout bearing, pilot bearing, replaced oil in transmission & differential. Ran truck through the gears with rear section of driveshaft removed & no vibration. Whle driving, step on clutch or put in neutral, vibration stops. Inside of transmission looks like new, no shavings, no visible wear on gears, bearing, synchros, or shift forks. Engine idles smoothly. Only other clue is a rattle in the shifter handle.
Any ideas or guesses??
Old 03-09-2024, 01:52 AM
Mumba's Avatar
Vibrations are coming from either your rear wheel bearings or the differential. I changed my rear bearings, still had the vibrations. So, I put it on jack stands, took out the rear driveshafts and run it. I still got the vibrations. That's when I zeroed it to the differential. Am yet to replace my differential but in the mean time, I want to use oil with a bit more viscosity.
crmx0312
11-20-2005 11:30 AM
bratan
11-10-2005 04:48 PM
guyonearth
07-15-2005 03:34 PM
alanis
06-08-2005 11:37 PM
MsJBody
05-08-2005 11:50 AM
Quick Reply: B2300 Vibration
