-   Mazda BT 50 & Pickup Trucks (https://www.mazdaforum.com/forum/mazda-bt-50-pickup-trucks-18/)
-   -   B2200 Carb Swap. How to? (https://www.mazdaforum.com/forum/mazda-bt-50-pickup-trucks-18/b2200-carb-swap-how-35504/)
Mr_Leffe 06-12-2015 09:40 AM
To swap out the stock carb and install a Weber on a California car (now deep in AZ dessert ) with all the smog parts how do you blank off the smog systems.
UseYourNoggin 06-12-2015 11:41 AM
READ this: https://www.mazdaforum.com/forum/maz...version-30671/
Make sure you click on links in posts.
Not sure if it's California Emission Approved, but it's all you get!
Mr_Leffe 06-12-2015 11:09 PM
3 Attachment(s)
Lots of interesting info..
I have a different motor. Mine is a B2200 with a primary cat-conv. which has 3 pipes that connect to the air filter container. This is my be a problem. Pics in the morning..
UseYourNoggin 06-13-2015 07:32 AM
Can't help you, the one i posted was from someone who posted it here, and i remembered it. Like i said, "it's all you get". :(
Mr_Leffe 06-14-2015 08:44 AM
3 Attachment(s)
Pics of the plenum with the 3 reed valves, plumbing running down to the primary cat/vert. Attachment point.
Can this all be discarded and blanked off.
Cusser 06-16-2015 08:34 AM
If your truck is not in Maricopa or Pima county, no emissions tests. I have this on my '88 B2200. You can plug the three rubber hoses with rubber stoppers from Ace Hardware, or just remove them, which I later did.
I made a steel block off plate and slid that in and bolted it down where the twin tubes bolt on. I use capped lug nuts ($6 pack of four) to seal off the four ports on the exhaust.
Mr_Leffe 06-16-2015 10:05 AM
So I can remove the whole pipe system and blank it of. Great. Any chance of pics.
Which Weber did you use? Where from?
Cusser 06-16-2015 11:37 PM
Some photos here, show the lug nut caps and the Weber.
MazdaBScene.com ? View thread - My October 2011 B2200 Engine Rebuild
http://www.cardomain.com/ride/233451...photo-gallery/
I had other photos but when Mazdatrucking.com had a crash, they were lost, would need to take new ones. Might be easier if you supply E-mail address and I could E-mail them over the weekend.
I used genuine Redline Weber kit #K675 (Weber 32/36 DGEV carb) from Top End Performance, about 2005.
