92 B220 Pick-up
Old 01-08-2006, 05:50 PM
NinjaSword's Avatar
Default 92 B220 Pick-up
Well Im new to this forum I just bought a 92 B220 gray pick up with 140,000 on the odameter and I paid 1100. Well I will post up picks as soon as I can.
where is the spell check?
Old 01-08-2006, 11:03 PM
bkey71's Avatar
Default RE: 92 B220 Pick-up
Welcome to the site, and post pics soon!
As far as spell check, you are on your own.
Old 01-08-2006, 11:44 PM
NinjaSword's Avatar
I will monday or tuesday, this thing does not have a radio. How can I find out how a wirirng diagram?
This thing idle a little rough, Seafoam? I think it would help.
Is this thing FWD or RWD?
Thanks guys
Old 01-09-2006, 12:39 AM
bkey71's Avatar
I guess Seafoam is a gas additive, never heard of it. Best thing to use is BG 44K bust must be purchased at a shop.
The truck is RWD.
Old 01-30-2006, 11:40 PM
NinjaSword's Avatar
Ok does this truck have a timing chain or belt?
I have not been able to take the pics yet I am just now able to drive it, The guy I bought it from never put it in his name so it took a while to fix that.
The truck runs great, But it likes to stall (sp) when the engine is cold/cold outside about 30 degrees.
What is recomended the air filter is clean, THe spark plugs are new, I think I could raise The idle but there is no tac So I only want to raise it a hair.
I put seafoam in it. Yeah sea foam is a gas additive. I usly drive Hondas I have a 99 accord also. Most people On Honda-Tech Recomend sea-foam.
also is this truck FI or Carb?
Old 01-31-2006, 12:17 AM
NinjaSword's Avatar
What kind of fuel economy should I expect out of this thing?
Old 01-31-2006, 12:59 AM
NinjaSword's Avatar
is it an interfearence engine? in case the belt does break will I bend the valves? if in fact it does have a belt
Old 01-31-2006, 06:22 PM
bkey71's Avatar
See next post. I goofed!
Old 01-31-2006, 06:25 PM
bkey71's Avatar
This truck does have a timing belt, I would get it changed soon if you don't know last time it was done. It should not be an interference engine far as I know, I don't work on these trucks everyday like babyhuey...he would know for sure. As for MPG I would think around 25-30 depending on driving habits and condition on the engine and drivetrain. It should be easy to determine carb or FI, Depends if the truck has a carb or has fuel injectors on the intake.
Old 02-02-2006, 07:57 PM
NinjaSword's Avatar
Quick Reply: 92 B220 Pick-up
