91 2600i clutch
Old 12-08-2006, 02:22 AM
mwce2's Avatar
Default 91 2600i clutch
I dont know if these trucks do this or not but my clutch seems a bit slow when I release if I take my foot off of it fast there is a slight delay for it to return back up clutch holds just fin do I just need to lubricate something?
Old 12-10-2006, 12:24 AM
kallgrer's Avatar
Default RE: 91 2600i clutch
Since these trucks have hydraulic clutches, they need to be bled if any air gets in the line. Bleed your clutch just like you would your brakes. Make sure the clutch master cylinder is full and with the wheels chocked, have someone depress the clutch. When the clutch is in, cycle open and shut the bleeder screw that is on the slave cylinder which is located on the passenger side of the transmission, then release the clutch pedal. Repeat this process until no more air bubbles are visible in the fluid. Don't forget to hook up a tube to the fitting on the bleeder screw so you don't get brake fluid everywhere. Enjoy!
Old 12-11-2006, 01:18 AM
mwce2's Avatar
Thanks I will try it
Old 12-14-2006, 02:10 AM
mazdab2600's Avatar
ORIGINAL: mwce2
i noticed this just a weekago with mine but it was cold(-20c)
it only did it a few times (4-5) and only that morning
will keep you posted if it happens again and if i find anything
Old 12-14-2006, 02:41 AM
mwce2's Avatar
Mine has done this far as long as I can remember.
Camo4x4
10-10-2008 10:20 AM
dmalensek
09-06-2006 08:33 PM
dmalensek
08-10-2006 11:57 PM
93_26004x4
07-04-2006 12:24 PM
wazzuup_34
02-17-2006 09:45 AM
Quick Reply: 91 2600i clutch
