88 b2200 heater problems
Old 12-07-2008, 07:14 PM
jtraider's Avatar
Default 88 b2200 heater problems
i have an 88 b2200 6 cylinder. i get no heat. i turn on the controls. the engine drags down until the breaker trips. once the breaker trips the engine returns to normal. no air blows out at any point.
Old 12-07-2008, 07:49 PM
Cusser's Avatar
Default RE: 88 b2200 heater problems
88 B2200s are 4 cylinders. You'll need to better explain "the engine drags down until the breaker trips". Does this happen when you just turn the fan on in "vent"?
Old 12-07-2008, 10:58 PM
Id like a better explanation as well. are you saying no air comes out of the vents at all?
or that air comes out until the circut breaker trips?
i have an 87 b2200, the blower resistor had failed and lost 1 or 2 of the fan speeds.
please clarify, no heat or no air flow from the vents.
Old 12-08-2008, 07:42 AM
jtraider's Avatar
its my father-in-laws truck so i'll have to check the cylinders again. but no, i get nothing at all no matter what the environmental controls are set at. doesn't matter if they are already on at start up or you turn them on afterwards.
Old 12-09-2008, 09:23 PM
Cusser's Avatar
More information is needed.
(1) Drive 20 minutes, feel the inlet and outlet tubes at the firewall; if both are hot, then your engine is delivering heat to the heater core (if not, engine issue). Report Y/N
(2) Does the fan blow air out the vents? Report Y/N
(3) If 1 and 2 are YES, then you have a flap/diverter doorissue; on these trucks that's operated by cable, you must look up from underneath while a helper flips the levers to troubleshoot.
Old 12-10-2008, 08:41 AM
jtraider's Avatar
there is a little heat trickling out. no air blows at all at anytime.
Old 12-10-2008, 09:12 PM
Cusser's Avatar
Sounds like no air blowing from anywhere. Does the blower motor under the passenger side of dash actually spin? If not, check blower motor,the blower resistors (which are mounted to the evaporator box if there's AC, or you'll see if you remove the glove box), and the switch itself. From your first post you may have a short somewhere.
tocostew
01-14-2011 07:32 AM
miketown
01-08-2011 11:08 PM
Rick
12-12-2010 07:12 PM
Kasstastrophy
01-30-2009 08:43 PM
Luvmyrx7
12-30-2008 03:54 PM
Quick Reply: 88 b2200 heater problems
