87 b2600 carb idle high
my truck(87mazda b2600 4x4) has 199000 miles on it and its idleing to high-3200rpm-seating still.ive had a new carb(webber) put on and two good shops,try to get it to idle down.and its still doing it.its a water actived choke-.the idler is all the way out.the thottle cables not in a bind.cant find air leak nowhere. does anyone have any ideas?thanks
it was a rebuilt carb.we went throw 5 different carbs.then company stop exchanging them.same problem with all, idles to high.i had 2 shops to try get it to idle down and couldnt. does any one have any ideas on how to get it to idle down?
Don't know if you got it figured out yet but mine had the same issue. Fixed it with a new neutral switch and vacuum lines. then the oil injectors gave up at hiway speed and it needed a new motor so I made a 4.3 chevy fit and work. Don't have any problems now.
Willie2124
06-17-2009 11:29 PM
blasphemous
02-28-2007 03:02 AM
ABTireman
06-03-2005 03:09 AM
