1996 b2300 climate control
Old 11-05-2006, 04:06 PM
jerryc2s's Avatar
Default 1996 b2300 climate control
When going to change the temp from cold to hot on the panel it does nothing the temp stays the same. I belive something is stuck somewhere but don't know where can you please help
Old 11-05-2006, 08:14 PM
Default RE: 1996 b2300 climate control
These trucks are known for breaking the cable for the temperature control. If thats the case then you will have to replace it, or manually change it by looking down by the gas pedal for a lever connected with a blue cable attached if yours is blue (mine is blue and i have seen others blue.) Just flip the lever up or down to change the temp.
Old 11-06-2006, 11:42 AM
the temperature control module//cable, i ment to say, could be broken
kingkleks
07-17-2009 09:21 PM
sonnystables
07-06-2008 11:17 PM
ontheair
05-22-2008 09:40 PM
mgopal
01-22-2008 09:49 AM
madgee
03-04-2005 12:34 PM
Quick Reply: 1996 b2300 climate control
