1993 B2200 how to change pinion seal
Old 07-02-2012, 06:43 PM
Lenl's Avatar
Default 1993 B2200 how to change pinion seal
Good day, i have a 1993 B2200 that has a leaky pinion seal, i removed the seal and drained the diff fluid, i have the new seal installed but read in the Chltons manual i should have measured the nut ft lbs when removing it. i would also need a new nut?
is there a correct way to install the yoke regarding bearing pre-load?
Thanks
Larry
little dutch
10-12-2013 06:00 PM
sphinxx187
09-30-2009 10:47 PM
Josdek
11-23-2007 11:07 PM
Mr. peepers
03-16-2007 01:21 AM
83rx7nutcase
01-14-2006 01:14 PM
Quick Reply: 1993 B2200 how to change pinion seal
