1993 B2200 (2.2l 2bbl engine) runs rough intermittently
Old 03-10-2018, 09:09 PM
chrisc1748's Avatar
Default 1993 B2200 (2.2l 2bbl engine) runs rough intermittently
Hi, my truck intermittently runs lean, this happens both on fast idle and normal idle. Also it could start running perfectly normal but then in the same drive it would run rough/ lean then go back to running normal again. I think the rough part is it becoming lean because it hesitates (makes that put put sound) on throttle input in the lower rpms up to about 2,000 then it starts to smooth out but a noticeable power loss. I suspect it is a electrical problem because it is the feedback carburetor and it is intermittent.
kenc
02-15-2012 04:34 PM
lortech
08-11-2010 04:38 PM
tribute owner
06-03-2008 10:27 AM
jimm
12-14-2005 11:28 PM
ABTireman
06-03-2005 03:09 AM
Quick Reply: 1993 B2200 (2.2l 2bbl engine) runs rough intermittently
