1993
RE: 1993
OK. Now (with the light switch "on") measure the voltage coming out from the dimmer ****, first try at both extremes of rotation of the ****. If you don't get voltage either way, and in the intermediate positions, you have a bad dimmer switch. You can try a jumper wire to ensure that the rest of the circuit is OK, and the dash lights should then come on. If you can live with dash lights just being "on" when the lights are on (without having adjustment capability) just bypass this switch. I did just that on my old VW bug when its dimmer portion of the switch shorted out; then it essentially comes on same as the parking lights coming on.
ozmazda1993
10-04-2005 05:58 AM
929woes
12
09-13-2005 10:24 PM
