1992 B2600i Timing
Old 08-15-2009, 08:45 AM
Rod Holder's Avatar
Default 1992 B2600i Timing
Hey guys,
As my issue with the engine was resolved (see post about idles fine will not rev...) I have moved on to other stuff. I just replaced the belts and rad hoses. I want to check the timing but the hood sticker says 5 deg BTDC "with idle tester hooked up" (or something to that effect).
Does anyone know what this is? I don't wnat to ignore it and set at 5 deg and then have it end up being way over advanced.
Any advice much appreciated......RH
Old 08-15-2009, 10:47 PM
Rod Holder's Avatar
Found it. It's a green connector with red wire on passenger side firewall. It needs to be grounded before adjusting idle speed and timing.
snojnky
07-23-2015 11:13 AM
cayeb
12-26-2007 08:47 PM
cayeb
12-20-2007 09:57 PM
IMPORTS
04-16-2007 06:11 PM
92mazdaman
11-13-2006 02:13 PM
Quick Reply: 1992 B2600i Timing
