1992 B2600I TIMING
1992 B2600I TIMING
MY TRUCK FAILED EMISSION TESTING TODAY ( NOX, CO & HC). I WAS ADVISED TO DO TIMING ON THE TRUCK FIRST. I HAVE A TIMING LIGHT AT HOME BUT I'M NOT SURE IF I'M DOING IT PROPERLY. ANYONE CAN ASSIST ME i WOULD REALLY APPRECIATE IT.
RE: 1992 B2600I TIMING
first turn the crank so you can see the notch on the crank pully and put some bright paint on it so you can see it while the motor is running. then jump the diag. connecter and use your light to set the timing to 5 deg. (give or take 1 deg.) by turning the distributor. also check your idle at this time.
92mazdaman
11-13-2006 02:13 PM
