1987 B2200 mil codes
Old 09-16-2009, 09:08 PM
Ksemerdjian's Avatar
Default 1987 B2200 mil codes
Hello I have a 1987 Mazda B2200 with a check engine light that comes on while I drive and hold the throttle in one place I have checked the codes and I get a code but I need to know if anyone has a link to a list of codes?
Old 09-16-2009, 11:20 PM
Default 1987 Mazda B2200
I also have that black soot on start up I have checked the codes they are 16 (EGR) and 45 (Pressure sensor which is connected to EGR) just bought this thing and it has been a pain!!!
Old 09-18-2009, 07:53 PM
Well that is what I think the code are thats why I need the list of codes for a 1987 mazda b2200
Old 09-18-2009, 08:55 PM
Found it just in case someone out there needs it! http://www.troublecodes.net/mazda/
Old 09-19-2009, 09:58 AM
Cusser's Avatar
The EGR valves on these tend to get stuck as they age, get covered in hard carbon. If you pull a vacuum on the EGR while idling, it should sputter and maybe stall out. New EGRs are expensive, suggest taking it off, cleaning out the carbon, see if pulling a hand vacuum actuates the lever, and that the lever fully closes when vacuum is not applied.
Old 09-20-2009, 11:58 AM
I have cleaned out the egr and I noticed when I pulled it off the second time it had already built up some carbon in a very short time also when you say pull a vacuum line do you mean just disconnect the line or apply vacuum so the valve will open? Any idea about the black soot that comes out of the exhaust is this connected to the egr problem?
Old 09-20-2009, 07:52 PM
Cusser's Avatar
When vacuum is applied to the EGR, the valve should open. Without vacuum, the valve should close ALL the way. The black carbon must be carbon that has condensed because the EGR is a few degrees cooler than the engine passages.
simmonsp5
09-21-2023 04:49 PM
Ksemerdjian
09-16-2009 09:10 PM
naraku137
05-30-2009 12:08 PM
kendoguy
10-14-2008 12:31 PM
BlackCar
05-22-2006 09:27 PM
Quick Reply: 1987 B2200 mil codes
