1982 mazda b2000 front oil seal leak
You're going to need to remove the rad, the fan, all the cooling hoses to the rad. both belts, remove the center support, and the grill. Get an impact wrench with a 21mm socket, and unbolt the lower front pulley assembly.
Once you have the assembly off, then the front seal is easy to remove, a small pick and dig it out, oil a new one, and slide it in where the old one came out, and reassmble the truck..
in/out takes about 2hrs each way.
sosube
12-30-2011 01:57 PM
