Won't start after engine replacement
I have a 2002 MPV I just had a used engine put in and now it will not start. Home based mechanic did the work, so I am sceptical on what he is now saying. He stated the key may need to be reprogrammed, or new key to match vin on engine? Does the security feature on the key have to match engine, or is this just programmed to something in the ignition? This project has had many unforeseen items, and I don't want to pay for another thing until I know it is needed and not just more money into it without results.
Nothing with the PCM or instrument cluster were changed I'm guessing. The electronics have no clue if it's the original motor or the 7th motor. Should start.
Does it crank? Security light flash rapidly with key in run position? Do you have a aftermarket security system or remote start? If so, disconnect the battery, turn the ignition to run, and reconnect the battery. Turn ignition off and then try to start the car. I've had a few successes with that. |
Originally Posted by Sparky202
(Post 156765)
Rapid blinking security light does indicate a miscommunication between key and PCM. May have to reprogram. Dumb question, but I'm sure you tried both keys.
I'm also assuming the clicking is the relays powering up and not the starter? |
I'm also interested in this
Trying the starter today. It started fine prior to the engine replacement. Mechanic still has it so I'm just going by what he told me. He said if starter doesn't fix it to tow to dealership to program.
