starting prob mazda mpv
hi
I have a 2003 mazda mpv diesel looking for advice on my starting problem I some times go to start it and it turns very slowly then leave it for a while and it then cranks ok and the engine starts I can run all day when started but when I stop and then go to start again it cranks slowly again leave it for a while and it starts ok again. today when I got in the car it would not crank I could hear the starter clicking in after a few turns of the key it started to crank but very slowly hence the car would not start. I had a check on the battery a while ago and the mechanic said it is fine any ideas would be appreciated regards malcolm |
Classic starter symptoms. Check all connections and replace the starter.
thanks for that im only hoping its connections or bad earthing
regards malcolm |
Since it is a diesel engine it has massive compression compared to a gasoline engine. That means the starter works really hard. Be careful of your replacement choice. A cheap starter won't last long.
thanks
hi again
do you know a quick test to prove the starter motor malcolm |
hi again
just had my son round and we put jump leads on from his jeep and it fired up first time could this meen my battery is goosed |
Most part stores will test the battery and starter draw.
ok thanks
ive got it in a garage this morning to check leads etc thanks Malcolm ps will let you know of outcome? |
