Sliding Door Lock/Unlock
Hi,
I've got a 2000 MPV DX van. Before I was able to lock and unlock the sliding doors from the master switch. But now whenever I press to unlock the doors everything works except the 2 sliding doors. This van has to sliding doors by the way. I've checked the fuses and it's good. What's the next thing I should do? I'm not sure which wire to test if the master switch is giving power to the door actuators. Any help would be great. Thanks. |
Is there a panel of copper/brass terminals that make contact between each door and the pillar when closed? If so, clean both sides and recheck the locking.
Diagram may be of a later model, but similar principle. Van Cafe: Vanagon Parts - Sliding Door Contact | Power Door Locks Google Image Result for http://www.van-cafe.com/shop/images/253.959.375.jpg https://www.google.com.au/search?q=M...60%3B418%3B357 |
Okay, I'll try that. I'll let you know. Thanks.
Hi,
I've tried cleaning the contacts and they're clean as a whistle both on the door and the frame of the door where it latches in. Any other ideas? Is there a way for me to check if there's power going to the actuators? Where would I be looking at the master switch? Thanks. |
When you press the lock & unlock button there will be a power signal at 1 or more of the terminals on the door pillar. Use a multimeter or LED testlight to check.
