PCV valve locaion on 03 MPV
Can you show me were exactly is the location of the PCV valve on a 2003 MPV LX? Thanx
RE: PCV valve locaion on 03 MPV
The answer to that question is one that you do no want to know if you are going to be replacing it yourself TonyMazda.:D
PCV valve is buried between the cylinder heads on top of the engine block between the #3 and #6 cylinders and is an absolute bugger to get at. Would show you a pic of it but with intake manifold and fuel rail assembly still installed on the engine you would not be able tosee it well enough.Am right now installing a new engine in a 02 Tribute V6 with same engine and PCV set up so will take a pic of it that way. [IMG]local://upfiles/1377/264C8AAAB281495C8472C181CD221F85.jpg[/IMG]Yellow X is on the PCV valve. It does not just pull out but must be rotated counterclockwise approx 90' and will then pull out as it is kind of threaded in. [IMG]local://upfiles/1377/1850791662344F058D5E92CBCF1A08C3.jpg[/IMG] |
babyhuey,
Is the PCV in the same location on the 01 MPV? -KWS |
Wow that sucks, & I thought it was hard to get to on my 3.0l Mazda6.
