P0421 and Hesitation at low RPMs
Need help to figure out what to change first!
14000K miles.Sporadic hesitation/miss at low RPM (about 2000 RPM-more noticablewhen cold). Trouble code indicates O2 sensors and/or catalytic converter. All are original. Here is the data from the reader that lit the MIL: DTC for which Freeze Frame was StoredP0421 Fuel System 1 StatusClosed Loop Fuel System 2 StatusClosed Loop Calculated LOAD Value38.82 % Engine Coolant Temp195.80 °F Short Term Fuel Trim - Bank 1-4.69 % Long Term Fuel Trim - Bank 13.91 % Short Term Fuel Trim - Bank 22.34 % Long Term Fuel Trim - Bank 23.91 % Engine RPM1866 rpm Vehicle Speed Sensor38.53 mph |
RE: P0421 and Hesitation at low RPMs
Oops... that's 140,000 miles... should have used preview!
