Oil leak somewhere on the top end
Old Feb 20, 2009 | 12:35 PM
dbirch2's Avatar
Default Oil leak somewhere on the top end
Hi all,
I am hoping for some sage advice.
My 1994 MPV 3.0 4wd has developed an oil leak somewhere on the top side of the engine.
I shampooed then engine to see if I could isolate the source of the leak but so far have been unsuccessful. Currently the oil pools at teh front end in a depression between the distributor(?) and the valve cover and in the same spot on the back side between the valve cover and the block out for where I am thinking the distributor would go if the engine were rotated 180 degree through the horizontal plane.
Is this a common problem?
Could it be a warped valve cover?
The oil tends to drip on a heat shield near the firewall and the fumes enter the cabin when the defrost is on. It is not a significant amount of oil but annoying when the windshield is foggy.
Thanks in advance,
David
Old Feb 20, 2009 | 05:37 PM
hixx's Avatar
The passenger side cyl head distributor blind plug o ring and pcv housing o ring leak where you describe. The same on the drivers front where they use o rings.
Jessev
Aug 6, 2021 10:03 AM
m3rock
Jun 2, 2015 12:10 AM
Fish94
Oct 12, 2014 01:25 PM
JJohnsonAZ
Apr 9, 2011 07:18 PM
du_ponts
Apr 14, 2007 11:12 PM
