No radio, gear indicator, reverse lights 1997 mpv
Good day, here's the situation.... 1997 MPV walked into is mid situation... told it was just a case of the neutral saftey switch. After that was complete it seems to work but now the radio the reverse lights and no gear indicator doesn't work unless the lights are turned on and then only the Neutral [N] lights up.... is there a relay or somthing cuz I am really lost. Any idea would be cool. Thks
RE: No radio, gear indicator, reverse lights 1997 mpv
I do not have a wiring diagram but it sounds like you need to inspect the wiring harness to the transmission carefully for poor connections or shorts as well as checking the fuses. All that goes through the CPU also.
