MPV stereo removal
I have a 2002 MPV, how do I remove the stereo?
Thanks |
RE: MPV stereo removal
Start by removing the entire trim panel that goes around the radio, instrument cluster and left side dash vent area. There are one or two screws recessed in the upper part of the trim of the instrument cluster. Remove them and then start pulling trim panel straight out toward you. Easiest to start at the left vent as there is something to grab onto. Lower tilt wheel all the way down, remove electrical connectors as you can reach them, and then pull trim panel up and out of the way. Four phillips screws hold the radio unit in which will be easily seen at this point. Remove and pull radio straight out and disconnect conector and antenna cable.
