MPV Fuel Line Relief Valve??
I need to replace the fuel pump, because it works intermittently, so where is the relief valve? The fuel system is normally under pressure; where is the valve located? I cannot find a repair manual for my 2000 MPV, soI appreciate any and all responses.
RE: MPV Fuel Line Relief Valve??
The only relief/check valve I am aware of is in the fuel recovery system.Usually if the vehicle has sat for a few days, most of the pressure is relieved. Or simply crack a line and release the pressure slowly that way. Protect your eyes and use a drain pan. |
