MPV 2003 Rear pre-cat o2 sensor replacment
I would am grateful for any detailed tips on how to replace this 0 2 sensor. Do components need to be removed to gain access? Removing the sensor itself looks doable, but could not see the plug-in end of the assembly.
Also, having replaced the front pre-cat O2 sensor and starting up engine, codes cleared, but engine still idles rough. original codes were:
P0131 O2 SENSOR
P0171 TOO LEAN BANK 1
P0172 TOO LEAN BANK 2
P0300 MISFIRE
a mazda mechanic mentioned something about, if i understood correctly, reseting the computer (or something like that) - - almost as if he was suggesting starting with 02 sensor replacement, but not sure that would take care of the problem.
thank you very much for your help.
P0131 O2 SENSOR
P0300 MISFIRE
littlebillybubba
Jul 27, 2006 01:11 AM
