-   Mazda MPV (https://www.mazdaforum.com/forum/mazda-mpv-17/)
-   -   Headlight Help (https://www.mazdaforum.com/forum/mazda-mpv-17/headlight-help-12486/)
daviddarville 01-27-2008 02:35 PM
Headlight Help
Ihave a 2001 MPV and lost both low beam headlights. The high beam works on both sides, but when I switch to low there are no lights. The high beam indicator light stays on for either high or low. I have replaced the bulbs but that did not fix the problem. Maybe a switch or relay??
Thanks ,
David
virgin1 01-27-2008 02:59 PM
RE: Headlight Help
If the indicator is staying on, yup! I'd say you were on the right track...
rdstar03ds 02-08-2009 08:48 PM
RE: Headlight Help
I know this thread is a year old, but I just started having the same problem with my 2001 MPV and was wondering how it was resolved.
"Ihave a 2001 MPV and lost both low beam headlights. The high beam works on both sides, but when I switch to low there are no lights. The high beam indicator light stays on for either high or low. I have replaced the bulbs but that did not fix the problem. Maybe a switch or relay??"
Thanks!
Dan
rodhunt 02-09-2009 12:40 PM
I'm having the same issue. Started the other day, I tried to replace the lamps and that did not work. Looking for suggestions.
Thanks
Rodney
