Sounds like it has an internal leak.
Are you seeing any (air) bubbles come up into the master reservoir when the pedal is depressed, or being depressed? |
cant see no air bubble when the peddle is being tapped but i can see the fluid go down but the rises again a little ? but if i push the slave cylinder in i can hear a hissing sound at the master cylinder and im really sure i should not be hearing that at all its sounds like fluid is being pushed back into the master cylinder or something like that.
