car stalls when brakeing afer rev??
2005 mpv will stall after i rev it slightly and press the brakes. fo example ill be driving to a stop sign and gradually press the brakes and it will stall.. only after hard exceleration.
any ideas on what it is? thanks in advance |
I'd suggest checking your battery: connections and water level.
Level was low on my mx3, and it stalled several times when hitting brakes. Many times when it almost stalled, power dropped low enough to kill the radio. Then i checked battery, topped off with distilled water, charged it, been good since then. Hope this helps... |
the battery is good i checked it.. but its only after a big rev of the engin then i hit the brake it stalls. it wont stall if i just hit the brakes randomly.
It may be a vacuum leak. Possibly the hose from manifold to brake booster, or brake booster itself.
I think when revving, there's more vacuum, so it may be a small leak that only occurs when there's a lot of vacuum... |
