Bank 1 Malfunction
i have a code P0170....FUEL TRIM MALFUNCTION (BANK 1) can anyone explain this code.....need to pass the smog check :eek:
RE: Bank 1 Malfunction
The o2 sensors constantly switch the fuel mixture from rich to lean above 2400 rpm to achieve 19.7 to 1 air/fuel ratio. If an o2 sensor is lazy and slow to switch it can kick this code as well as a vacuum leak/dirty injector etc.
thanks Hixx...:)..... i will check all the lines and change my O2 sensors......van is 11 years old I guess its about time to replace the O2 sensors.....can I use a universal type sensors :eek:?
Yes the aftermarket sensors are fine.
