BabyHuey!!! RPM's up and down at startup only
BabyHuey,
Thanks to this forum I diagnosed and performed the PCV hose changeout successfully for my friends MPV. There was a visable hole in the hose elbow on the back of the engine. The husband is in Iraq, and she was getting the P171, P174 codes. While I had things apart, I sprayed some electronics cleaner in the MAF wires, and throttle body cleaner in the throttle body and plate area. I also cleaned other electronic wire harnesses I unpluggedto do the PCV hose replacement. Everything worked great, but now when you crank it up ( I think just when it is cold) the idle goes up to like 1500 RPM, then down to 700, then back up, then back down in the course of 10 seconds, up and down....It eventually stops after about 2 minutes? Without understanding much about the MAF, could I have damaged it with the cleaner, or can you think of anything else I could have gotten into...? I may have left some throttle body cleaner fluid in the body, without wiping it down real good... Any thoughts? I will try to look at it this weekend. What should I look for.... |
RE: BabyHuey!!! RPM's up and down at startup only
Help, anyone have any ideas.. I have to look at it tomorrow.
not sure if it is better.. I did remove the IAC and it was cruddy inside. I sprayed carb cleaner and operated the "plunger" while spraying...
It moved more freely after I cleaned it... I started the car up fine, but the engine was warm, and I think I have to test it on a cold engine.... I hope that did it, because is was sooooooooooooo easy..... |
