airbag warning lights
What is code 45 on airbag dash light
What year is it?
2000 import mate
The US models differ so i am unsure if it is the same vehicle code 45 is not a valid code for US models. I would assume 45 is the passenger side seat sensor. If the light bulb is burnt out of the passenger side airbag select switch then it will set a code. The bulb is soldered into the switch but can be replaced if you can solder.
