Accessing front door speaker
How do I access the speaker in the front door of a 1991 MPV? It's starting to crackle at us, and I'd like to replace or disconnect it. Thanks!
RE: Accessing front door speaker
There are only four phillips screws holding the door panel on. Two are at the front and rear lower corners of the door panel recessed in holes in the carpet. One screw in the door pull and one in the inner handle. Once they are all removed and the black trim piece is removed from front the front top corner area, just pull outward on the trim panel and it will pop out.
