-   Mazda MPV (https://www.mazdaforum.com/forum/mazda-mpv-17/)
-   -   2005 Mazda MPV 3.0 V6 Oxygen Sensor (https://www.mazdaforum.com/forum/mazda-mpv-17/2005-mazda-mpv-3-0-v6-oxygen-sensor-26745/)
MPV_2005 May 30, 2011 10:40 AM
Hi,
I own a 2005 Mazda MVP, my vehciles sevice engine light came on, since that i took the vehicle to auto zone to check the code and came up with bad 02 oxygen sensor, i need to know how to replace. is there more than one, if so which one should i replace. what is the difficulty on replacing, please advice, any information will really help. dont have much money to put in the shop.
thanks to all
Deathwish657 May 21, 2012 11:53 PM
Which Oxygen sensor is it? There are like 3-4 different ones. If you know the Code they got that would actually give you a good spot to be looking since it would give you the location more when its looked up online.
My code i got is PO155 = Oxygen sensor 1 Bank 2
(Ofcourse i still never got it fixed.. Replaced it but something else still making it not work..)
UseYourNoggin May 22, 2012 07:34 AM
You won't get a response. That was 1 year ago. Damn thread sort.
Deathwish657 May 23, 2012 03:31 AM
LOL. Yea.. I realized that after i posted :P
steffanj May 25, 2012 05:40 PM
Po155
Hi all I have a Mazda Tribute 2001 with the check engine light on. I have had it diagnosed as PO155 heater core circuit. Is this sensor easy to change as there is two upstream sensors. Also My fuel economy has gone through the roof is this to do with this sensor.
Steff
Deathwish657 May 26, 2012 06:48 PM
Bank 2 is where cylinder #2 is at. (Cylinder #2 is in the front of engine, closest to radiator) Sensor 1 is the sensor before the catalic converter. In total, there are 4 sensors.
2 Upstreams, 2 Downstreams.
They are not hard to replace, just gotta get the o2 socket set to get them, since they are in a tight spot. Connection for bank 2 sensor 1 is near the cooling hoses, under waterpump area.
thegolffather Jul 18, 2017 02:04 AM
Wow great information, I wish it had pictures
05MPV Sep 13, 2017 10:11 PM
had both pre cat sensors replaced and now no more CEL and back to normal fuel mileage
Soljhon Dec 14, 2019 03:51 PM
How many o2 sensor are there on mazda mpv and where are the locations.thnks
smspitler Dec 18, 2023 11:08 PM
MPV 3.0 has 4 O2 sensors. Two upstream (prior to the converters) and 2 downstream (after the converters). Bank 1 is closest to the firewall and bank 2 is closest to the radiator.
