2004 MPV- Airbag code 18 - HELP !!!
I have spent hours looking for a Code 18 for my 2004 MPV.
I can't find an 18 anywhere on the web.... it's definitely one flash, a pause, and 8 quicker flashes. I just failed my MA inspection and need help. |
There is no code 18 in this list, double check to make sure that is really what your getting. Also try to unhook the battery for a while (10-15 mins) and reconnect it, the SRS system has its own capacitor/battery backup but it isnt too large, really only for if your in a crash and the batt is destroyed and you get hit again e.t.c.
DTC TABLE |
Also check your PASSENGER airbag light, if its not working it will throw a light on your side, code 1818.
Bingo...you got it. I thought it was repeating a code 18 x 2. its actually an 1818.
I just spent another hour checking all the connectors I could reach and pulling the battery again. I just realized the passenger side airbag light was not activating. I just came back in to check the forums for "no pass. airbag light. I was able to get the middle console open enough to fiddle with the light connection and that didn't work. Any other ideas? Are there any in-line fuses anywhere? I checked all the fuses in the two boxes and they were all good. thx |
I would just try and change the bulb since its probably blown, cheap an' easy...........well ok maybe not EASY but definitely cheap :D
Found the bulbs at Advanced Auto 2 for $5. It worked. In the last I have gotten rid of a CEL and an SRS light for $9. I can't imagine what it would have cost at the dealership.
Thx |
Oh I am sure it would have been at least $100 just for the "diagnosis" then shop supplies and parts +labor.................
