2002 Mazda mpv trunk wet
Hello I was wondering if anyone has had a problem were when it rains the trunk is what I call it is wet indicating a water leak I have checked all the gaskets around the rear hatch door and don’t see any problem |
you will need to strip out the interior trim panels, hop inside the boot, & get someone to hose down the back of the vehicle, while you look for the entry point.
Leak
Thanks for the quick reply i had read that there was a service bulletin about drilling drain holes under the rear bumper have you ever done or heard of this |
Nope.
Thanks were would you suggest purchasing a shop manual I have purchased 2 Emanuels and they show very little detail it a 2002 mpv 3.0l |
Help with leak
Originally Posted by Radford129
(Post 172324)
Thanks were would you suggest purchasing a shop manual I have purchased 2 Emanuels and they show very little detail it a 2002 mpv 3.0l Hi, Did you solve your leak? If so how? I have a 2001 MPV and the back trunk is wet. The bottom of the carpet is wet but the top sides are not. I cannot figure out where the water is coming from. |
