2001 MPV has many personalities...
Maybe my MPV is not multi personality, but I beginning to wonder. Check this out
I go to get my 2001 MPV inspected and receive the following problem list State Inspection 1. Power Steering Pressure Sensor Circuit Malfunction 2. Warm up Catalyst Efficiency Below Threshold (Bank 1) 3. Warm up Catalyst Efficiency Below Threshold (Bank 2) 4. Cooling Fan 2 Control Circuit Malfunction Mazda Dealership finds the following problems 1. Engine Light 2. Spark plugs 3. Spark plug wires 4. Coil pack 5. Left and Right Catalytic convertors 6. Both top Oxygen sensors 7. Powertrain Control Module reprogrammed 8. Power steering pump switch Auto Zone 1. Power steering pressure switch 2. Catalytic convertors Bank 1 3. Catalytic convertors Bank 2 4. Cooling fan relay 5. Spark Plugs 6. Ignition wires 7. Coil So I make some repairs I replace plugs and cables and return toAuto Zonewith no improvement So, I unhooked the battery, as suggested by a mechanic, to see if the repair are codes cleared.Go back to Auto Zone No problems found So I go to a different Inspection Station 1. Catalyst 2. Evap 3. EGR system So is my van may not be confused, butI know I am...Any ideas????? |
