1992 MPV not starting..
Hi!
I just bought a Mazda MPV 3.0 four weeks ago and the engine is not starting. the starter is working, but the engine wont start. i already had that a few weeks ago, that it took a bit longer to get the engine started. any ideas? oh, and if i take of the battery, is there a code on the radio? and can i change that code before taking of the battery? cause i dont have that code... thank you! Karsten |
RE: 1992 MPV not starting..
ok, now i checked the cables, they still look good. i cleaned the airfilter, cause it was really dirty (propably about 50 gramms of dirt just by hitting it against the hand! I think i need to change it) I refilled the oil, cause it was only at the low level. now its between low and high.
when i turn the key to "ON" all lights go on and after a few seconds only the battery, fuel and oil warning lamps stay on. is that the usual that the oil and fuel lamps dont go off? The car is still not working. :( |
You need to replace the air filter, the fuel filter, engine oil and oil filter and all the spark plugs. After you have done this, let us know how it went.
Marty |
