02 MPV Rear Heater Lines Replacement
Has anyone replaced the rear Heater Lines on their MPV? Lines are seeping coolant and the lines are on order. Also ordered 3 plastic line brackets and 2 gromets. Doesn't look like fun. Anything??
Disregard my request.
Disregard my request. I replaced the lines with factory spec replacements, and it is not worth the trouble. Heater lines run above the A/C lines and the brackets that hold the inner fender well safety cover in place, are not on the replacement lines. I suggest either capping the rear core off and putting in a hose on the lines to recirculate the coolant or run heater hoses using zip strips. Very not worth it. Then there is the issue of bleeding the lines.
