Splash guards -fender wells
Old Mar 15, 2007 | 12:59 AM
Am4wag's Avatar
Default Splash guards -fender wells
Are the splash guards the same on all the Millenias (year/model) ? I have one missing and one that is mangled.I know a junkyard that has about 10 Millenias,but not sure if all are the same.
I need to replace a parking light bulb,and it looks like I need to remove the fender well splash guards to get to one bolt that holds the headlight assembly in.These are fastened with phillips snap-in plugs ? Is it a matter of snapping these of and getting some new ones from (say) the help section at the local auto parts?
Old Mar 19, 2007 | 07:32 PM
babyhuey's Avatar
Default RE: Splash guards -fender wells
The wheel well liner for right and left side is same part number from 1995-2000. The philips snap in plug should be removeable and reuseable as well. Use a phillips screwdrivers to thread center part just like it was a screw. If the outer part is turning also then hold it still with a little pick.Once the center part is threaded out the outer should pop right out and be ready to use again.
Old Mar 19, 2007 | 10:07 PM
Am4wag's Avatar
I can see the power steering fluid revservoir from underneath the car,unlike the driver's side that has a splash pan in place.Looks like the fender well liner comes down and meets the lower one.Oh,BTW-so much for the junkyard-they crushed them.So I'll probably be going to the dealer and ordering what I need.One of the larger ones that are under the engine,the dealer told me 72 dollars.Kind if high for a piece of plastic,but not unreasonable considering my other options which for now are zilch........
Craig
Sep 16, 2007 12:33 PM
BU_Jack
Mar 18, 2007 01:37 AM
tke270
Mar 4, 2007 09:12 PM
mongolloyd
Sep 5, 2006 06:19 PM
JfromPA
Aug 27, 2006 03:26 PM
