remote starter 98 millenia 2.5
Okay heres the deal I have a 98 millenia and i have installed a remote start for my wife for christmas. Well after working it for about 5 hours getting it hooked up the blower motor does not turn on when car is started. The remote start will not turn on the heated seats can some one tell me if there is another wire coming off the ignition that would start the blower motor.
A wiring diagram of the ignition would would be nice if anyone has one. Please help Thanks |
RE: remote starter 98 millenia 2.5
When you wired in the remote start for the run circuit of the ignition switch did you only power up the ign 1 circuit? That would have been the Black wire with white stripe from ignition switch. The seat heater relay coil is powered up by ign 2 circuit which is the Black w/ Red stripe wire. The blower motor relay coil is also powered up by ign2. Powering up that wire might get both to work although the A/C amplifier also gets a power on signal from the ACC circuit which is the Blue wire. Would try to get power to that ign2 circuit first and see what all comes on.
