Jacking up 2002 Millenia
Old 11-11-2023, 10:41 AM
RamJacCorp's Avatar
Default Jacking up 2002 Millenia
Other than the standard jacking points under the rocker panels, where can I jack up the front of the car to do an oil change? Does anyone have a diagram or photo showing the best front jacking point? I've searched and only found a few diagrams, and couldn't really figure out what I was looking at (including in the manual). Of course, I'll be placing stands under the rockers for safety.
Old 11-11-2023, 11:54 AM
For DIY.. lThe model needs to either use the factory jacking points or ramps ONLY. Any other way you are likely to damage something.
Old 11-11-2023, 12:56 PM
RamJacCorp's Avatar
Thanks for the quick reply, Callisto. I was hoping that there was a suitable crossmember up front. :-(
Old 11-11-2023, 01:08 PM
While I could not and would not use the cross member because any slip and you could damage your suspension or alignment setting.
Humanly unsafe but can be done in a pinch or desperate need. Jack up one side as if changing a tire place a jack stand under the lower control arm and then raise the other side and place another jack stand.
Old 11-11-2023, 04:10 PM
RamJacCorp's Avatar
Thanks again for the advice. I wish they'd designed it in a way where you could place the jack and the jack stand in the same spot on that pinched jack spot. Nah, that'd be too sensible.... Have a great weekend!
alanm.ainsworth15
05-28-2019 11:27 AM
dbclark44
01-12-2011 04:59 PM
Bucky1
06-15-2009 05:39 PM
skillaphill
11-07-2007 06:40 PM
mihulka
11-13-2006 02:37 AM
Quick Reply: Jacking up 2002 Millenia
