Milly overheats despite new radiator
I had my 01 Millenia S checked at my local garage because of overheating at idle. They dx radiator leak and said the thermostat and hoses were all fine. I replaced the radiator myself this morning. I probably should have replaced the thermostat at the same time but didn't. The car is still overheating, but seems to be getting hotter faster than before. If I run it at 50+ it cools down but heats up very quickly in stop and go traffic or at a light. Any suggestions?
Sounds like the cooling fans are'nt running. At 50 mph it does'nt need the fans since it has a 50mph wind across the radiator. At idle it needs the fans.
When I stopped and left it running the fans were both going. I'm almost embarrassed to ask this, but if I didn't add enough coolant after installing the new radiator would it act the way I described?
That both fans were running is good.
That you short changed the engine on coolant is not, and could be the reason for the rapid overheating. You should top up the coolant, turn the interior heater to full hot, run the engine at a fast idle for about five minutes, recheck the coolant level, and top it off as needed, and repeat until the coolant is being displaced into the overflow reservoir to a depth of an inch or so. (This ensures that any residual air will bubble through the overflowed coolant and be replaced by coolant sucked back from the reservoir as the engine cools). Your garage should have done a thorough cooling system maintenance if they found the radiator was leaking. If it had to be repaired or replaced, the full treatment is to drain and flush both the radiator and engine, replace the top and bottom hoses, replace the thermostat, inspect the overflow hose and reservoir for integrity, and check the cooling pump and its belt drive condition and tension. Then test drive the car ensuring that engine temperature is normal, interior heating and air conditioning are OK, and that both of the cooling fans are operational. Finally, pressure test the cooling system, inspect for leaks and verify that the engine exhaust is colorless. (White exhaust is OK on start up, but coming from a warmed up engine it indicates water ingress into the engine, usually caused by a head gasket failure or a cracked head or block). |
Overheating
Vehicle starting overheating: found the hose to the heater core was broke (changed/fixed). Then a small hose above the thermostat housing leaking (had a hole,changed/fixed) Car still overheating. So we changed the thermostat. Car still over heating not as fast but slowly going to Hot. What could it be (radiator,water pump...) out of things to look at. Pls help. Im gonna try one thread i read about not having enough coolant. Now it that does not work im lost.
thanks in advance 2MuchChik sorry it a 97 mazda millenia |
Did you make sure you filled properly with coolant? If it is slower to overheat than it was it may be low. I only bring it up because, like an idiot, I made that mistake. ;)
There could be a leak in the radiator. I found mine by having it pressure tested at a local garage. ($80 I think) They wanted $425 to replace the radiator. I found one for $125 and did the job myself. Good luck! |
Originally Posted by africansteve
(Post 110459)
| All times are GMT -5. The time now is 08:20 AM. |
