Did you every try the main relay? Did it fix the problem
Did you ever try the relay? What was the result?
I have the same issues on my 2002 2.5L, but after replacing the main relay fuse it is still stalling and stammering. Does unplugging the EGR sensor still work as a sufficient fix? Also, what ended up being the long-term repair for this issue?
Did anyone find out the fix for this problem? I have the same issue... 500rpm intermittent drop while driving. I changed all vacuum hoses, rotor and cap, wires, plugs, cleaned EGR, cleaned IAC, cleaned ground points (under air box, next to thermostat, in fuse box). going to disconnect egr booster now
| All times are GMT -5. The time now is 05:53 AM. |
