Looking for Someone To Repair. I Am In Connecticut
My Mazda Millenia Is giving Code P0300 and P0173 and I need specialize in premium Japanese and German imports to fix it for me in a reasonable price
A fuel trim malfunction can result in random misfire and random misfire can sometimes register as a fuel trim malfunction due to how the ECM processes fuel trim feedback. So, I'd start looking for air leaks from bad or misrouted vacuum hoses since that's the more likely culprit, then move on to troubleshooting the fuel system. Of all the possible causes for both codes, these are the more likely ones (in no particular order): Fuel pressure regulator control (PRC) solenoid valve malfunction Fuel pressure regulator malfunction Purge solenoid valve malfunction Spark plug malfunction Coil malfunction MAF sensor contamination Vacuum leak between MAF sensor and dynamic chamber Purge control solenoid valve malfunction EGR valve malfunction PCV valve malfunction |
May I suggest to do an Internet search for Japanese automotive specialists in your specific area? e.g. "Japanese automotive specialists, Stanford, Ct." and see what you get. |
