Knock sensor problems
Ok.... This has been an nightmare
i am getting a code knock sensor circuit 1 (bank 1) p0325 and baro sensor circuit p1195. I have checked the knock sensor by putting my meter on the lead to the sensor and setting for milli a/c volts. Taped next to sensor and getting a rise of 10 mili volts. Its defianalty rising and not rising during taping. The baro sensor i have not really invesigated other than seeing if vacuum lines attached. I was going to check the wiring all the way back to the ecu but i cant get enough slack in the wires to get the ecu out. Not sure if i could get the connector hooked back up. Very tight. If i clear the code and it immedialy comes back evne without starting the engine. The baro code requires me to run the engine for it to post. |
WELL I ALSO FOUND THE AIR INTAKE SENSOR IS "OPEN" PER THE MANUAL. THE MANUAL STATES THERE SHOULD BE REISISTANCE BETWEEN THE PIN AIR ROOM TEMPATURE. I HAVE NONE.
I THINK LIGHTING HIT THIS CAR. F ME!!! I HOPE THIS WILL FIX THE BARO PRESSURE SENSOR ERROR CODE. ANY SUGESTIONS?:mad: |
